Welding Projects ...mig, tig, and stick
weldmonger store
piggy bank welding project
Socket weld bookends
Harbor Freight Hand Truck welder cart full web page
Fire pit build full web page
Dead Blow Thor hammer full web page
Slide hammer spatter tool
Tig brazed cube
Aluminum tote tray
Stainless steel manifold
Rocket stove
Welding Cart Project
welding cart project part 3
welding cart project part4
welding cart part 5
Welders Third hand tool
mig welding a jeep bumper kit project
Welding Projects are fun. I am trying to do more of them to mix things up and make my videos more interesting. I think seeing a weld done on a real welding project is more fun to watch than just sticking 2 pieces of metal together.
This has got me scratching my head for new ideas so I just ordered a 5 volume series from the James F Lincoln foundation (jflf.org) to get new ideas for projects.
mig welder boom arm project part 2
thick aluminum mig welding project using a lincoln powermig 350mp part1
Welding alumnum with a Lincoln Powermig 350mp part 2 I had a thick aluminum welding job come in and used this lincoln powermig 350mp with mk push pull gun. WOW!!
fabricating a belt guard for an air compressor part 1
welding a shop stool seat using tig
One of the most useful welding projects ever...
downdraft cutting table project
one of the absolute most useful welding projects I ever made is a downdraft plasma cutting table.
Not a cnc type plasma table, just a table that gets rid of the smoke from plasma cutting, torch cutting, stick welding, or grinding.
part 2 plasma cutting table welding project
Shop Stool welding project
Fabricating a Shop Stool - welding project
Welding a Jeep Bumper from Swag off road using a Hobart 210 mvp
One of the most fun and easiest welding projects I ever built was a rear jeep bumper kit from swag off road. ( swagoffroad.com)
The bumper kit practically puts itself together....and the Hobart 210 mvp runs sweet using .035" er70s-6 wire and 75/25 gas.
DIY press brake kit from swag
Another easy welding project that turns into a handy piece of shop equipment once its done...is a press brake kit for bending metal.
Its designed to be used with a Harbor Freight press but also works with any similar press.
SWAG off Road makes some really great stands for portable band saws. swagoffroad.com
But they dont make a stand for my Porter Cable. So I made one myself and now I use it all the time..Its that handy.
Sometimes I need to make a quite cut on some tubing or threaded rod. IT works great for quit cuts. And I can take the portaband out of the stand to make cuts in a vise if I need to.
DIY portaband stand
talk about useful welding projects?
A stand for your portable bandsaw converts an already useful tool into a vertical bandsaw for cutting round stock, notching sheet metal, and more.
And anytime you want to use it as a portaband, you just pop it loose and go to town.
A stand for the portaband stand
a stand for moving the portaband stand around the shop seemed like a very good idea.
Turns out I was right.
I dont move it much. It stays plugged in in the corner most of the time but occasionally, I wheel it over next to my welding table to trim or notch long pieces without need roller stands.
Links to welding projects pages
aluminum tig welding
arc welding project
homemade anvil
hydraulic shop press
metal fabrication
miller dynasty cart project
plasma cutting project
portable bandsaw stand project
portable band saw stand
slide hammer puller project
welding projects
weld repair stainless steel exhaust
What is your latest welding project?
Welding Projects Posted Below
Click below to see free welding projects from other visitors to this page...
Ricrkp
I recently bought a MITTLER BROS 36" bead roller for doing embossed panels and auto interiors. The machine is FABULOUS but the stand that they offered …
Konstrukcje-Malbork -Poland
We kind of picked up this TIG welding stainless and it pays off. Here another welding challenge. Idea the same as pump on the cart but much more sophisticated. …
The Alumiweld Canmaster X-treme 3000
This is a jig I made to weld aluminum cans together.
Welded metal Flowers
It started as a gift for my girlfriend and has now began to grow as a side job/projects
I made this nice portable pump cart for company which sells pumps.. They usually just sell pumps but customer wanted to make it portable so they would …
Dave
This is a project made for a friend who has a take away business it is a combination of a steel square frame with a a 304 stainless steel top and clad …
Rolling Stand For The 'Clutter Catcher'
After seeing Jody's video review of SwagOffroad.com's tool organizer, I knew it was made for me. It's intended to bolt to a bench edge, but I wanted …
My Brother's Head Stone
Just a little something to honor my Brother with....He was a good man, And I was honored to be able to build his head stone ( not Stone ).
Fume hood from clothes dryer
Fume extraction does not necessarily require filtering. If you were going to release smoke into your local environment anyway, vent it outside the building. …
Bear Paw Prints
Here’s a photo of my first completed welding project … ever. It’s kind of a steel, stone, and glass project – with a finished wooden cabinet thrown in …
my bumper
i had a bunch of scrap 10 gauge plate and some 2x8.5 inch rectangle tube around the shop so i made a bumper for my 06 ram -------------------------------------------- …
Decorative fireplace screen
1/8 inch steel bar 3/4 inches wide, 3/4 inch square tube .065 wall thickness. All finished in patina. Welded with miller diversion 165 tig welder
aluminum sun sculpture
1/8 inch aluminum sheet use to make this decorative sun. Arch is 1 1/2 inch wide strip curved to semi circle. Rays are tigged to the arch. -------------------------- …
Texas lace weld cover pass
Texas Lace weld 6010 cover pass on pipe
DIY Twostroke pipes RZ350
Some 6 month ago I got myself a cheap 180A TIG welder and started a bit of practicing. For the second project I chose to build some pipes for my RZ350. …
Martin K.
Some 6 month ago I got myself a cheap 180A TIG welder and started a bit of practicing. It was astonishingly easy, so I decided to build a bike lifter …
Stainless Steel Tig Sculpture
Hey jody, i love the work you put into this site and your videos, Keep doin what youre doin. Anyways my name is Sam Houston and im 18 years old. I made …
churrasqueiras de butjão de gás de refrigeração
no ano de 2010 fiquei desempregado por parte do destino, perdi meu pai com um tumor no cerebro, por tanto comecei o meu projeto, comprei um soldador bambozzi …
Wagon made from scrap steel
I rebuilt a trailer for my father-in-law and was able to salvage some of the steel for a garden cart/wagon. Comparable wagons at Ace Hardware or NorthernTool.com …
TIG Welder Cart
I have a 110A Century MIG welder that I have used to fabricate equipment for my company, myself, friends and neighbors in my garage/shop, but was limited …
Harbor Freight Welder and Welding Project Video
This was the first project that I built with my Harbor Freight 90 amp flux cored welder. Please see the video for more information.
CACTUS SUNRISE HEADACHE RACK
Made this headache rack for my 2010 F-150. The Virgo(artsy-fartsy) in me said that a headache rack should not only serve it's function, but …
welding turntable
This is a work in progress. Pictured here is a little welding turntable I am making for fillet welding round tubing to flat. The aluminum rings are from …
4x6 bandsaw base
Okay...so...I have a band saw that is pretty top heavy. The stand that it sits on is less than desirable and border line dangerous. Since …
HEAVY DUTY HEADACHE RACK
Project number three. I'm on a friggin' roll! .......big-shot cattle rancher saw my dog cage on Craigslist, wanted me to make a headache rack for …
Prerunner Bumper for My Truck/SUV
ok so i have wanted some off road bumpers for my truck and all the ones online were about 1,000 bucks but im 17 and i make about 500 a month and i pay …
Sheet metal roses
Jody- Came up with an idea to recycle some sheet metal stuff I've had lying around. Hope you find it interesting. Have a Miller Thunderbolt XL that I converted …
NEW AND IMPROVED TRUCK BED DOG TOPPER
Soon to be registered....."KATY KAGE". Namesake of a Queensland I had for 16 years. This sequential, slip-fit, breakdown design I came …
mobile pet enclosure #2
As promised, new and improved,"swoopier" version of my truck bed dog pen. This one to be used mostly for goats. Materials used:1 …
Rob
My kids love messing around on karts (and generally on anything with wheels). They wanted a go-kart that could carry a friend. We looked at some ready-made …
There aren't too many things my dogs like more than ridin' in the back of a pick-up truck (save killin' and eatin' two-thirds of a gopher, then bringing …
need frame welded
need frame welded for 6foot wide 13 ft ft.long 7ft high box trailer steel frame school project ok will furnish all material and supplys. phone al at 619-582-4797 …
25 buck log splitter
basically i have improvised a lot with my design just by looking at other peoples design and making my own, using a scrap peice of railway track approx …
Aluminum Powered Paraglider Trike
Just thought I'd share a recent project. A friend wanted a custom built aluminum trike to mount his powered paraglider motor and wing. He wanted …
Plezuh Slovenian Sledge - Aluminium Welding Project
This is a traditional Slovenian Sledge - 31.01.2010. Thank you for showing my work on your site.
Sleeping Pod welding project
Aluminium Sleeping Pod welding project- 2009. YouTube video
Mr.
Tig and Coolant Trolley from leftover materials. ----------------------------------- Gabriel , that is very cool and innovative. jody
Lead Fabricator
This is a stainless steel parts cart.It took about a week to build to get all the details right after an inspection by the customer and doing some minor …
Batmobile Tumbler gokart
I just thought that I would submit the first big welding project that I have ever done. It took me 4 months to design and 5 to build. The rear is made …
My welding rig
I started hearing things about a natural gas boom from the Marcellus Shale in Northern Pa and Southern NY. I then decided to build my own welding …
Tube or Rod Welding Jig.....
Ever run out of material, either a piece of tubing or rod, and just had a few pieces of "too short" leftover pieces? Here's a handy jig I designed & …
First Mig Welding project
This is my first welding project. I just welded links from an old anchor chain in a curve, to look like it was growing out of the ground and to serve as …
Nickle-Cadmium battery welder
Dad made a battery-powered welder, and constructed two trailers for homebuilt aircraft with it. The bottom two boxes contain surplus Nickle-Cadmium batteries …
Fish cooker from rebar
Not for deep-frying turkeys, but for boiling greasy parts in soapy water. Strong enough to stand on and wiggle around. A bit springy when standing on it, …
Replacement 4x6 bandsaw stand from bed rail
To lay out this stand, put the saw base casting upside down on a table, bolt the rough-cut legs onto the casting, and adjust them symmetrical with a carpenter's …
MIG (GMAW) 4F and some 2G
roughly a 2 meter long, x 1 M wide, x 1 M high frame and structure made from 2" x 4" x 2" x 1/4" c channel and 1/4 plate (gusset and channel extensions). …
brian
jody, i am posting a couple of pictures here to support your theory that vert. UP hard wire is stronger and can look good with some practice. A friend …
brian
Redneck Barbecue Grill
Hi Jody and fellow welders! A friend of mine came over to my welding shop one day with this 55 gallon steel barrel and asked if I could make him a barbecue …
6" Drain Pipe Trencher for Excavator
My brother's got a small excavation and water control business and wanted a less labor intensive means of laying drain pipe. We dreamed up a trenching …
Steal This Bike!
When I was first introduced to welding it was an instant passion. I bought my Miller 175 Amp Mig to do repair jobs mainly on my mufflers as I was able …
exit welding projects and see more welding videos
