25 buck log splitter
by sinka
(australia)
basically i have improvised a lot with my design just by looking at other peoples design and making my own, using a scrap peice of railway track approx 7 foot i built a solid end peice usin 1 inch plate wth supports running to the end of the track.
after extending my ram source off an old harvester and hoses collated from the farm . i then mounted it and built my spliiter onto the end.
realizing that this will need to be Mobile i found an old differential and welded it straight on and welded another piece of plate on with a hole cut in it so it can be towed with ease eventually i will make it independent with a hydraulic motor and engine until the it is on the back of the tractor
Return to welding projects.
