Short Welder Settings Videos that are much better than a weld calculator
I have used the Miller Weld Calculator quite a bit for when I need some quick MIG settings to get me in the ball park.
Weld Calculators and MIG charts are OK for a starting point.
But weld calculators fall short when it comes to overhead, vertical, pipe welds, and any other weld that is not done flat on a workbench.
So I am making hundreds of short 30-45 second video pages that not only list detailed weld settings, but show a quick video of the weld.
Meanwhile, why not take the Free Trial at welderskills.com and see hundreds of other welding videos done by select instructors like, JD Brewer, Roy Crumrine, Brad Goodman, Sam Hagan, and others.
You will see Settings listed like this on each Welder Settings video page
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 140 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4943
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 6
ADDITIONAL SETTINGS = AC BALANCE 30% CLEANING, AC FREQ 100HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Stick Welding 6g Pipe test 6010 Root
Did you know?..
Welder settings are not the only factor in making a good weld but they sure do help.
And when they have been proven out using cut and etch testing, you can be pretty darn sure they will work provided you clean your metal and use sound techniques.
