Weldmonger Stubby Gas Lens Kit
If you are still using the standard cups and hardware that came with your 17 style tig torch, you are not getting the best possible results....Especially if you are tig welding stainless steel, nickel, or any high performance alloy.
tig-stainless-jazzy-yt-thumb
learn more about the Best in Class Weldmonger® stubby gas lens kit
A True Story about How a Gas Lens Pays off...
A friend of mine...(lets call him Ray)  told me a story about his first day on a job at a  fab shop that welded heat exchangers.
The very first job the Boss put him on was to repair 172 leaks on a heat exchanger that had failed the hydro leak test.
The heat exchanger body and tubes were  Haynes 188 alloy and was valued at over 90 thousand dollars ....and with 172 leaks, they were considering scrapping the part.  (Boss man was not happy).
Haynes 188 welds a lot like stainless steel ....unless you get it all oxidized with poor gas coverage and then it welds like mud and can crack easily.
The part had been welded using a standard collet body cup and all the welds were crusty and dark with 172 of the welds leaking from crater holes and tiny cracks.
After grinding out all the defects, Ray put on a  #8 gas lens cup from his Weldmonger Stubby gas lens kit he had brought to work in his tote bag.
Then he set in to re weld all 172 leaks.
A few hours later, he finished the last weld and sent the part for the hydro leak test.
No leaks.  Boss very happy!
So on Rays first day on the job, he saved a 90 thousand dollar part from the scrap bin.
Here is the question....
What would it be worth to make that kind of first impression on your first day on the job?
When you show up on a new job, you can't always depend on them having the best TIG cups or hardware for you to use.
Ray was smart and brought his own Gas Lens TIG kit with him on his first day on the job and it helped him make a lasting impression.
Don't be afraid to invest in yourself.
Having the right gear can make all the difference.
Stainless steel loves argon
When a stainless weld puddle is shielded with argon and is free from oxides, it flows better and at less amperage.
But when you dont have quite enough argon shielding, the puddle gets way more sluggish and does not flow as nicely.
Having that little bit of extra smooth argon flow can make a huge difference.
Especially for those times when you need to extend your tungsten to reach a tight spot or tight angle like on cluster joints or gussets.
Benefits of using a Weldmonger stubby gas lens kit
Using a gas lens for TIG welding stainless steel offers several key benefits
Here are the main advantages:
  1. Improved Gas Coverage: A gas lens disperses shielding gas more evenly than a standard collet body, providing a smoother and broader gas flow around the weld pool. This is especially important for stainless steel, as it prevents oxidation and contamination, which can lead to discoloration and also a puddle that does not flow smoothly due to oxides floating in the puddle.
  2. Reduced Turbulence: The gas lens helps reduce turbulence in the gas flow, which can otherwise cause oxidation of the puddle by drawing in air. With less turbulence, the gas shield remains stable, protecting the stainless steel weld from atmospheric exposure.
  3. Longer Tungsten Stick-Out: Gas lenses allow for a longer tungsten stick-out (distance between the tungsten tip and the nozzle), which provides better visibility and reach, especially in tight or awkward spots.
  4. A Weldmonger Stubby Gas lens kit shortens the tig torch and allows you to weld in tighter areas
  5. A Weldmonger Stubby Gas lens kit includes furick gas lenses with o ring grooves that allow for using furick clear cups like the clear #7 and 8 pro cup,  jazzy 10, or furick clear 12.  Once you have the weldmonger stubby gas lens kit, you can upgrade one cup at a time without needed to buy additional hardware or adapter kits.
What TIG cup is best for aluminum
Some welders prefer a standard #5 collet body cup for tig welding aluminum.
I think a #6 stubby gas lens works great as an all around cup for most aluminum jobs up to around 250 amps.
