TIG Welding Videos...The best collection of Tig Vids on the net
no bs tig workbook
Tig welding with a Stubby Gas lens on Stainless Steel
carbon steel fillet welds
The videos above show arc shots and tig welding techniques for fillet welds on outside corner, lap and tee joints.
I used a Furick 8 pro , jazzy10 ceramic, and Furick Ceramic 12 ...all of these cups are in stock in weldmonger.com
Aluminum bike frame tig welding
The video above shows Mike Zanconato tig welding an aluminum bike frame. At the end of the video Mike explains independent polarity settings available by using the miller dynasty 280 expansion card. ( also known as amplitude settings)
tig welding coped tubes
The video above shows tig welding coped tubing using er70s6 as well as er309 stainless filler wire.  I used a Furick #12 clear cup so that you can see the arc better
tig welding titanium
the above video shows tig welding a titanium test plate in a test fixture with argon purge on the back side. I used a furick BBW ...in stock at weldmonger.com
tig welding steel and black oxide coating process
aluminum intake manifold project part 1
aluminum intake project part 2
aluminum intake part 3
er70s2 vs er70s6
scratch start tig tips
welding distortion tips
309 tig rod for stainless to high strength steel
making a tig rod rack, pulse settings, and a homemade tool using a cheap screwdriver
walking the cup on stainless
TIG welding thick aluminum on DC with helium
Welding a Thin Aluminum outside corner in .040" (1mm)
tack welding thin aluminum
Tigging an Aluminum Tee ...click for full article
Cold rolled lap joint..click for full article
Welding aluminum with the Lincoln Tig 175
gravy tig job part 2
pulse tig gravy job
Welding Art Batman
Tig Welding Aluminum Tee 2f
Tips for 11ga cold rolled steel laps
Open butt root pass techniques
Tig technique Pulsing with Foot pedal
Tig Welding/Brazing with silicon bronze filler rod
Tig welding basics part 5 -torch switch 2t and 4t settings
Socket weld bookends
Tig welding basics part 4
TIG Torches
tig basics part 3
tig basics part 2
TIG BASics part 1
walking the cup on a 2 inch schedule 80 6g welding test
Scratch Start Tig tips for avoiding craters
tips for welding thin metal with a 3/32" tungsten
tig welding stainless holes with a welding spoon
Tig Welding Cast Iron to 409 stainless
tig welding stainless steel with a stubby gas lens kit
scroll down for more tig welding videos
tig weld stainless tubing and tips for how to purge.
tig weld 1045 steel to 4140 using inconel 82 rod to tig weld 1045 steel to 4140 steel
Old School Scratch Start with a Twist Scratch start tig welders are still being used all the time. A DC stick welder, tig torch, bottle of argon, and flowmeter is all you need.
HTP Tig welder settings This video shows the affects of AC frequency adjustments and practical application of settings
tig welding techniques like walking the cup this video shows tig welding techniques like walking the cup vs not along with lay wire and dip techniques. Also a shameless plug for the tig finger
tig welding video about making a belt guard for an air compressor outside corner joints and twisting up mig wire to tig weld cold rolled steel.
tig welding aluminum using an htp invertig 221 welding an aluminum valve cover as well as some really thick 6061 t6 bars stock
welding a bike frame using er70s-2 and weldmold 880 rod welding the bike frame. Fixturing on the Stronghand Tools Build Pro precision welding table.
tig  video on welding tubing..thin stuff tig welding thin wall tubing used for custom bike frames using high speed pulse settings...the rule of 33, and a tungsten grinder. also comparison between er70s-2 and weldmold 880 tig welding filler rods.
tig welding high strength steel parts using the "Big white tig cup" TM to weld high strength steel parts
socket welds fit up and weld video socket welds used for making a chin up bar. 1 inch schedule 40 pipe and socket weld fittings tig welded. tig welding aluminum 3F tee vertical uphill tips for welding a 3F position TEE joint using 11 ga 6061 t6
tig welding repair and tips for identifying metals tig welding repair on a C clamp. Some would think this C-clamp was cast iron. Here is a down & Dirty test to tell if its cast iron
Tig welding a seat for a shop stool using pulse outside corner and lap joints using pulse tig and the rule of 33
tig welder comparison tips for using lift arc tig welders. A scrap piece of copper helps a lot
tig welding 9 random tasks welding build up on aluminum, razor blades, stainless handles to carbon steel nuts, boat prop repair and more
stainless steel weld repair job weld repair on a mis machined stainless shaft
tig welding an aluminum boat prop oct 2, 2012 weld repair on a blade of an aluminum boat prop using a tig inverter
tig welding quick job short video shows tig welding carbon steel to stainless using 309 tig wire. also shows tack welding technique
multi pass tig weld on thick stainless steel Video shows multiple passes walking the cup as well as using a tig finger
DIY bronze hammer welding project
a cheap and useful welding project that makes for a bronze face heavy hammer for tapping on finished surfaces you dont want to ding up.
tig welding lap joints this one shows lap joints on 11 ga cold rolled steel, 4140 multi pass, and also welding a bearing sleeve
tig finger in action on pipe etc.
pipe welding test
part 3... this link will take you to part 3 of a 3 part series on tips for taking a pipe welding test on a 2" schedule 80 6g test.
a review of root and hot pass and then...stick cover pass
6g 2 inch schedule 80 welding certification hot pass
this video shows tips for the hot pass in 2 inch schedule 80 pipe done in 6g position.
also, a review of amperage used for the root pass....and a review of reasons to buy a tig finger
6g 2 inch schedule 80 welding certification root pass tips for the root pass in 2 inch schedule 80 pipe. lay wire welding technique as well as dip and keyhole technique.
A 6g pipe test is pretty hard. You could use some tips.
Remove a Broken bolt from exhaust manifold a tig welder with a foot pedal and some 309 stainless tig wire and you are in business to remove a broken stud
All Purpose Water Cooled Tig Torch video Watch all the Tig Welding Videos you can stand right here.
tig video showing technique on root pass with a tig finger
tig video showing settings comparison using 3 tig inverters a tig welding video with arc shots
aluminum tig welding and ac balance settings
tig welding 4130 chromoly tips
how to tig weld steel corner joints
welding aluminum laps and tees with tig
tig welding aluminum parts
Aluminum Butt Weld
tig welding techniques for stainless
cast aluminum welding tips
tig welding carbon steel with 309 tig rod
tig welding stainless steel parts
Tig welding steel parts on a stronghand welding table
Aluminum Welding Practice A great way to get plenty of aluminum welding practice
Do the aluminum drill
tig welder demo Miller Diversion vs Everlast 185 micro tig welder comparison video
welding 4140 is a lot like welding 4130 which is a lot like welding steel... carbon content is the main difference..
how to tig weld overhead video
tig welding overhead is mostly a matter of figuring out how to be comfortable and how to hold the torch.
tig welding techniques and welding magnesium
magnesium castings can be repaired using tig welding... the same techniques used for aluminum work with some tweaks...
Walking the cup vs not... tig welding video
Walking the cup for Tig welding works good sometimes. Especially on pipe larger than 2 inches dia... other techniques can be just as good....
Aluminum Properties and how to weld There are a few things you need to know about all aluminum welding ... aluminum is hot short..that means it cracks easily at certain temperature ranges. That is why tack welds done with no filler dont work.
Welding Stainless to Carbon using hastelloy W tig rod
Hastelloy W works for all kinds of different steels. But it is very expensive. ...312 stainless is almost as good for when you are not sure of the steel you are welding.
metals and how to weld nickel
nickel alloys like inonel, hastelloy, nichrome V, and waspalloy do not need as much heat and have a sluggish puddle.
properties of stainless and how to purge ...one of the properties of stainless is that it will sugar if not purged on the back side and that looks like Fido's ass. This short video on the oxidation properties of stainless shows how to purge and weld.
properties of stainless and how to weld it tig welding video on the properties of stainless steels...best practices for welding stainless to keep it from rusting
metals and how to weld them properties of metals
welding certification test practice practicing for a welding certification test...part 2
tig welding test tips for tig welding practice
tig welding techniques tips for tig welding lap joints and butt joints
tig welding razor blades tips for welding razor blades and why you should sharpen your tungsten like a freaking needle
tig welding techniques for pipe welding root pass and fill passes without walking the cup. weldtec tig torch ..a small water cooled torch
rated at 320 amps... thats what i said...320 amps
exit tig welding videos and go to main video archive page
