Tungsten for TIG Welding Aluminum
Watch the Best "Back to Basics" Video on TIG Welding Aluminum. click here
tips-aluminum-email
What are the 3 Best Tungsten for TIG Welding Aluminum?
It depends but here are my thoughts...
In my opinion, the best all-around tungsten for TIG welding aluminum among 2% Lanthanated (Blue - WL20), E3 (Purple), and LaYZr (CK Worldwide’s blend) is ...
2% Lanthanated (Blue - WL20).
Here's why:
• Provides a stable, focused arc with minimal arc wandering.
• Works well with both modern inverter TIG machines and older transformer machines.
 Handles Heat Well
• Unlike pure tungsten (which balls nicely but does not carry much amperage), 2% lanthanated resists overheating.
• It maintains a fine-pointed or slightly balled tip, leading to better control.
 Longer Electrode Life
• Outlasts E3 and LaYZr in many applications.
• Doesn’t wear down as quickly, meaning less sharpening and replacement.
Versatility
• Works well on AC (for aluminum) and DC (for steel, stainless, and other metals).
• Great multi-purpose tungsten if you switch between aluminum and other materials.
How E3 and LaYZr Compare
(I cant tell the difference in these two tungsten types)
• E3 (Purple)
• Similar to 2% lanthanated but wears slightly faster.
• Arc starts are excellent, and holds a consistent tip at medium amperage but heat resistance is not as high.
• Good alternative but not quite as durable for extended aluminum welding.
• LaYZr (CK Worldwide Blend)
• Designed specifically for AC welding, combining lanthanum, yttrium, and zirconium.  Also works great for DC low amp start applications and performs well on multiple restart consistency.
• Provides great arc stability and a strong tip, but not at high amperage range like 2% lanthanated.
If you want the most reliable, long-lasting, and widely used tungsten for aluminum, 2% lanthanated is the best all-around choice. It provides: ✅ Stable arc
✅ Good heat resistance
✅ Longer lifespan
✅ Versatility for AC & DC
