TIG WELDING ON 1 INCH THICK ALUMINUM BUILD UP BEADS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS =  1 INCH
WELD TYPE = BUILD UP SURFACING
JOINT TYPE = BUILD UP
POSITION = FLAT
AMPERAGE =205 AMPS  CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4047 (4047 CAN HELP LESSEN POROSITY ON CASTINGS)
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE =  8 GAS LENS
ADDITIONAL SETTINGS =   AC BALANCE 35% CLEANING, AC FREQ 50HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
tig aluminum
