TIG Welding Mild Steel
3 of the Best Videos you will find on TIG Welding Mild Steel
Video #1 is a Better Way to learn to TIG weld mild steel by alternating beads of aluminum and mild steel
Video #2 Shows a Corner Joint, Lap Joint, and Tee Joint on 11ga mild steel using both ER70S-2 AND ER70S-6
Video #3 Shows the importance of cleaning mill scale before tig welding mild steel along with tips for welding stainless, aluminum, and other alloys.
Mild Steel is another term for low carbon steel.
It is easy to work with. Easy to weld, easy to bend, drill, grind, shape, etc.
Mild Steel does not crack easily and does not harden much when heated and quick cooled
High Strength Steels and 4130 chromoly have higher carbon content and other elements that make them more likely to harden during the welding process.
Depending on the thickness, a preheat is often used on high strength steels and 4130 chromoly to slow the cooling rate and prevent hardening.
Thick 4130 and 4140 require a preheat
4130 chromoly tubing .120" wall thickness can be welded using ER70S-2 filler rod without a preheat
Video Shows Arc Shots and Tips for TIG Welding a 3F lap joint on 11ga Carbon Steel
2 Short videos show Carbon Steel TIG Settings for 11ga 2f Tee joint with and without pulse
Quick Video shows Carbon Steel TIG Settings and Technique for 11ga tee joint
