Carbon Steel TIG Settings for 11ga Tee Joint
Quick video shows an 11ga tee joint at 128 amps
scroll down for settings
This is a super short video and all the settings are listed below.
If you want to learn more about tig welding carbon steel fillet welds watch
the full length video on carbon steel fillet welds here
Settings for 11ga carbon steel 2F tee joint fillet weld
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 131AMPS CONTROLLED WITH PEDAL TO 128 AMPS MAX
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
8 Pro Combo Kit includes both Clear and Ceramic cups
The 8 Pro Combo kit opens up lots of possibilities for other Furick Cups both Clear and Ceramic
This video will help you know what cups you need for your type TIG torch
