TIG WELDING ALUMINUM SQUARE TUBE 1/8" WALL BUTT FULL PEN 5 CUP
Video Shows 7 Tips for TIG Welding Aluminum
tips-aluminum-email
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061 SQUARE TUBING
THICKNESS =  1/8"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G
AMPERAGE  = 110-130  CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4943
POLARITY = AC
GAS FLOW = 12-15 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
tig welding aluminum square tube
