TIG WELDING ALUMINUM 1/4" THICK 3F VERTICAL LAP
Scroll down for detailed settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/4”
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 3F VERTICAL
AMPERAGE = 210 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/8” 4943
POLARITY = AC
GAS FLOW = 15CFH
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 25% CLEANING, AC FREQ 85HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
