TIG WELDING ALUMINUM 1/4" THICK LAP 2F
Scroll Down for all the exact settings
The thing about Aluminum that makes it more challenging to weld is the thermal conductivity.
The piece welded in the video above required 200-225 amps.
If that piece was twice and the same exact thickness, it would probably have required another 10-20% more amperage due to the conductivity.
Thats where a low preheat of 150-200F can help a lot.
Preheating aluminum slows the cooling rate, drives off moisture, and lessens the amperage required.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/4”
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 225 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/8” 4043
POLARITY = AC
GAS FLOW = 18CFH
CUP SIZE = 7
ADDITIONAL SETTINGS = AC BALANCE 30% CLEANING, AC FREQ 77HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
var l = window.location.href,
d = document;
