TIG WELDING ALUMINUM .063" CORNER JOINT SETTINGS 110 HZ
METAL TYPE = ALUMINUM 6061
THICKNESS = .063"
WELD TYPE = FILLET
JOINT TYPE = OUTSIDE CORNER
POSITION = FLAT 1F
AMPERAGE = 85-90 AMPS ( BACKING MATERIAL REQUIRES MORE AMPS THAN WITHOUT)
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 13-15 CFH argon
CUP SIZE = 6
ADDITIONAL SETTINGS = AC BALANCE 35% CLEANING, AC FREQ 110HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
Did you know?...
***Its Easy to sign up
No Ads, No BS style
var l = window.location.href,
d = document;
