For Cast or Dirty Aluminum, letting the cleaning action work before puddling along with good gas shielding and 4047 filler can help get the job done better.
METAL TYPE = ALUMINUM CASTING
THICKNESS = 1 INCH
WELD TYPE = GROOVED OUT CRACK
JOINT TYPE = REPAIR
POSITION = VERTICAL
AMPERAGE =200 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4047
POLARITY = AC
GAS FLOW = 15-18 CFH argon
CUP SIZE = 6 GAS LENS
ADDITIONAL SETTINGS = AC BALANCE 35% CLEANING, AC FREQ 60HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
NOTES AND TIPS: USE CLEANING ACTION TO BOIL OUT CONTAMINANTS BEFORE MELTING.
THIS MIGHT NEED TO BE DONE SEVERAL TIMES FOLLOWED BY STAINLESS WIRE BRUSH OR CARBIDE BURR OR BOTH BEFORE PART IS CLEAN ENOUGH TO WELD
