Tig Welding Aluminum 1" plug to 1/4" wall tube balled tip
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS =  1 INCH PLUG INSERTED INSIDE 1/4” WALL TUBE
WELD TYPE = FILLET
JOINT TYPE = LAP
POSITION = ROLLED ON TURNTABLE
AMPERAGE =200 AMPS  CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE =  6 GAS LENS
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 60HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
NOTES AND TIPS: ROUNDED TIP PRIOR TO WELDING USING BALL FUNCTION ON WELDER.
tig-welding-aluminum-balled-tip-turntable
