TIG WELDING ALUMINUM 11GA 1F CORNER JOINT SETTINGS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = OUTSIDE CORNER JOINT
POSITION = 1F  flat
AMPERAGE = 140  CONTROLLED WITH FOOT PEDAL (ACTUAL AMPS FOR MOST OF JOINT WAS 120-130)
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-18 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 31% CLEANING, AC FREQ 120 HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
