TIG WELDING ALUMINUM .078" 2F LAP joint
METAL TYPE = ALUMINUM 6061
THICKNESS =  .078"
WELD TYPE = FILLETWELD
JOINT TYPE = LAP
POSITION = 2F
AMPERAGE = MACHINE SET TO 120  AMPS CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE =  6
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 60HZ
PRE FLOW = 1 SEC
POST FLOW = 7 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
