TIG WELDING ALUMINUM .063" 1G BUTT JOINT USING STEEL FIXTURE
scroll down for weld settings
Video Shows 7 Tips for TIG Welding Aluminum
tips-aluminum-email
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS = .063”
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G FLAT
AMPERAGE = MACHINE SET TO 80 AMPS WITH FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 69% EN, AC FREQ 100HZ
PRE FLOW = 1 SEC
POST FLOW = 5 SEC
