TIG WELDING ALUMINUM .063" 1G TEST D17
I started using clear cups strictly to film the arc better.
But I quickly realized that they help me see where I am going better.
METAL TYPE = ALUMINUM 6061
THICKNESS =  .063"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G
AMPERAGE = 73  AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15-18 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 100HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND LIMIT TORCH ANGLE
