Tig Welding 11ga Aluminum 2f outside corner cube project settings
grab a tig finger at weldmonger.com
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = OUTSIDE CORNER JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = 120-135 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE = 8
ADDITIONAL SETTINGS = AC BALANCE 33% CLEANING, AC FREQ 100 HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
