Tig Welding aluminum 11ga lap joint clear 5 cup and settings
Clear cups like the furick ally #5 can light things up for older eyeballs like mine
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 120-135 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 100HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
tig welding aluminum
