METAL TYPE = ALUMINUM AN FITTING
THICKNESS = 1/4” TO 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 140-170 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4943
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS = AC BALANCE 30% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
