TIG ALUMINUM .125" OUTSIDE CORNER 50HZ
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = OUTSIDE CORNER JOINT
POSITION = 1F FLAT
AMPERAGE = 120-135 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS = AC BALANCE 31% CLEANING, AC FREQ 50 HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
var l = window.location.href,
d = document;
