TIG ALUMINUM 1/4" THICK TO 1/8" 2F FILLET
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/4” TO 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F
AMPERAGE = MACHINE SET TO 200 AMPS WITH FOOT PEDAL MAXED AT TIMES
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 70HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
