TIG WELDING ALUMINUM 1/4" THICK EDGE BEAD BUILDUP 50HZ
METAL TYPE = ALUMINUM 6061
THICKNESS =  .250"
WELD TYPE = BEAD ON EDGE
JOINT TYPE = EDGE BUILDUP AT 50HZ
POSITION = FLAT ON TURNTABLE
AMPERAGE = 100-120 AMPS
FILLER WIRE = 3/32” 4943
POLARITY = AC
GAS FLOW = 13-15 CFH argon
CUP SIZE =  6
ADDITIONAL SETTINGS =   AC BALANCE 35% CLEANING, AC FREQ 50HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
