TIG ALUMINUM 1/4" THICK AHP SETTINGS BEADS ON PLATE
need tungsten?
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/4"
WELD TYPE = BEAD ON PLATE
JOINT TYPE = SURFACE BEADS
POSITION = FLAT
AMPERAGE = 195 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 12-15 CFH argon
CUP SIZE =  6
ADDITIONAL SETTINGS =   AC BALANCE 25% CLEANING, AC FREQ 80HZ
PRE FLOW = MANUAL
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
