TIG WELDING ALUMINUM 11ga BUTT 1G SQUARE TUBING
scroll down for settings
Pushing a 200 amp tig welder to its max using an air cooled 17 style tig torch.
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8”
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G
AMPERAGE = 200 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 70HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
