TIG ALUMINUM .125" LAP JOINT SETTINGS
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 135 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 12-15 CFH argon
CUP SIZE = 6
ADDITIONAL SETTINGS = AC BALANCE 25% CLEANING, AC FREQ 80HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
var l = window.location.href,
d = document;
