TIG ALUMINUM .063" LAP JOINT 60HZ
scroll down for settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  .063"
WELD TYPE = FILLET
JOINT TYPE = LAP JOINT
POSITION = 2F
AMPERAGE = 80 AMPS ON MACHINE CONTROLLED BY FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 60HZ
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
