TIG ALUMINUM .063" LAP JOINT 120HZ
METAL TYPE = ALUMINUM 6061
THICKNESS =  .063"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F
AMPERAGE = MACHINE SET TO 80  AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 7 SEC
higher ac frequency settings often require more amperage than lower settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
