TIG Welding Aluminum Pie Cut Tube .063" thick
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = ALUMINUM 6061TUBE .063” WALL TUBE
THICKNESS = .063"
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = FLAT
AMPERAGE = 125 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC 250HZ
GAS FLOW = 13-15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS = AC BALANCE 35% CLEANING, AC FREQ 250HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
var l = window.location.href,
d = document;
