Mild Steel TIG Welding Settings
Scroll down for Simple Settings
PRIMEWELDTIG225-EASY-SETTINGS
There are a lot of knobs and settings on newer tig welding machines.
But when it comes to mild steel tig welding settings,
Fortunately, most of them can be set once and ignored
It starts with making sure the TIG torch is plugged into the correct port.
This will almost always be the negative plug and will usually have a small TIG torch icon label.
Read the manual for your machine to be sure.
Typical mild steel tig welding settings will be as follows on most machines.
  • DC Electrode Negative (DCEN)
  • Pulser off
  • pre flow set to .5 seconds
  • post flow set to 7-10 seconds
  • 3/32" tungsten (2% lanthanated, thoriated, ceriated, or E3 will all do fine)
  • #7 cup with 14-21 CFH argon flow
  • Amperage set to one amp per thousandths of metal thickness (up to .125")
These are the Basic Mild Steel TIG welding settings to get started...There are Hundreds of other pages here showing specific TIG settings for all types of TIG welding
tig videos button
TIG Welder Settings for Carbon Steel...From Thin to Thick
Did you know?..
Tig welding carbon steel from .063" -  1.00"
(1.6mm- 25mm) settings
Tig Welder Settings for Carbon Steel Fillet Welds
Top 3 tips for TIG welding Mild Steel
arc-length-quicktip-video-thumb
  1. aim for an arc length that is equal to or slightly less than electrode diameter (arc length is distance from tip of tungsten to puddle)
  2. limit torch angle to around 15 degrees ( torch angle can be very forgiving provided you hold a tight arc)
  3. Keep the hot tip of filler rod shielded in the argon plume and snip off the tip for restarts if tip has is discolored... or not kept shielded in argon
The fact that you found this page, tells me you are interested in getting better at TIG welding.
There are hundreds of free tig welding videos here at weldingtipsandtricks.com but if you learn better with a structured course that is designed in ABC...123 fashion based on years of teaching TIG courses, Then let me encourage you to take our Free 7 day test drive at welderskills and take advantage of our TIG course free for 7 days.
