Lucky 7 Clear cup Combo Kit for TIG Welding aluminum
A better way to Learn how to TIG weld
This video shows a unique and better way to get better at TIG welding by switching back and forth from Steel to Aluminum.
For quality Welding Gear shop https://weldmongerstore.com/
There are lots of opinions on what is the best tig cup for aluminum.
Some prefer a standard collet body with a #5 cup.
Others prefer to use a #6 or 7 gas lens setup.
No matter what cup you like to use , tuning the AC balance and Argon
flow rate will help you get the best results.
AC balance and Argon Flow Rate go hand in hand.
I started using clear cups strictly for filming instructional videos but
I learned quickly that they not only help me film the arc, but they
also light things up and help me see better.
More Videos on TIG Welding Aluminum
