AC TIG Welding Aluminum
scroll down for videos
how-to-tig-aluminum-yt-thumb
tips-aluminum-email
Key Factors for AC TIG Welding Aluminum
  • TIG Welding Machine (What is the best Value TIG welder that performs well, if affordable, and the company has great customer support?)
  • Shielding gas for TIG welding aluminum
  • Best tungsten type for tig welding aluminum
  • Settings for AC Tig welding aluminum
  • Best cups for ac tig welding aluminum
  • How to select filler wire for TIG welding aluminum?
TIG Welding Machine
primeweld 225 tig with stuff
Argon is the best all around shielding gas but as you get deeper into it, you can explore other options like argon/helium mixes and other specialty gases like STARGON AL.
tungsten-video-thumb
Personal preference plays into what tungsten type is best for tig welding aluminum.
2% lanthanated is a great all around choice but it depends on your specific application.
Some newer tig welding machines have tons of settings for AC welding... like different wave forms, amplitude offsets, and more.
some of those settings can make a difference in very specific applications but in my opinion, the fundamental things that make the most difference for AC TIG Welding Aluminum are:
  • Cup size and gas flow tuned properly
  • AC balance set properly for each application and even depending on humidity
  • AC frequency set properly ( this one is very forgiving)
But the main settings for AC TIG welding aluminum are AC balance and AC frequency.
AC balance, cup size, and argon flow rate need to be tuned on a piece of scrap aluminum for best results
The best cup for TIG welding aluminum depends a lot on personal preference but also on thickness of aluminum and joint type.
A lot of welders prefer using a standard collet body with a #5 cup.
others prefer a #6 or #7 gas lens.
There are welders getting great results with both collet bodies and gas lens setups.
It seems that welders who like to pulse with the foot pedal for that stack of dimes look prefer a standard #5 cup and collet body with a very short tungsten electrode stickout.
what filler wire for TIG welding aluminum?
4043 and 5356 are the 2 most commonly used aluminum filler rods.
This Hobart aluminum filler metal chart is very helpful in selecting what TIG rod to use
