METAL TYPE = ALUMINUM 6061
THICKNESS = 3/8” TO 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
AMPERAGE = 225 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon/helium mixed with Y
CUP SIZE = 8
ADDITIONAL SETTINGS = AC BALANCE 30% CLEANING, AC FREQ 77HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
