Tips for 5F Weld Tests
3/32" 7018 5F Weld test
a 5F weld test usually involves at least one cross section macro etch test to test for penetration into the root of the joint.
A 5F weld test is a fillet weld test that is a tube welded to a plate where the tube's axis is horizontal and the plate is vertical. A 5F weld test is considered more difficult than a 2F weld because of the body positioning that is required to maintain a favorable line of sight and rod angle.
5/32" 7018 5F Weld test
TIG Aluminum 5F weld test
5F MIG Tube to Plate
Short circuit MIG requires a bit of arc manipulation to make the bead less convex. One technique that helps keep the arc at the leading edge of the puddle is the upside down V motion
Video shows tips for Passing a 5g Downhill Pipe Welding Test for API 1104 with Arc shots, Tips, and Techniques
Instructions on How to Cut and Etch welds with Video
Videos to help you pass 6G tests with 6010 root
var l = window.location.href,
d = document;
