Yet more job posts in the Portland metro area
by John
(Portland, Or.)
Experienced Welder wanted (Wilsonville/Aurora)
Experienced Welder wanted for aircraft component manufacturer.
We are a healthy manufacturing company looking for the right person to join our team.
Must have at least 3yrs tig experience with thin wall steel and aluminum. Welding test will be part of interview.
Tube bending experience prefered but not necessary.
Full time position. 4 x 10hr days.
We are a drug free workplace.
Please email resume with contact information to this ad.
Thanks!
email contact: job-m66qk-1548185698@craigslist.org
Compensation: $15-$20/hr depending on experience. Health insurance, 401K
WELDER, EXPERIENCED
WELDER, EXPERIENCED needed FT to tig light gauge stainless 14g-12g. Polishing exp. required. Fax resume to: 503-774-2550 or call Paul at 503-774-7342
Fabricator/Welder (Hillsboro)
Small fabrication & machine shop looking for the right person who has the following;
Exerpience in both mig & tig welding (carbon, stainless, alum)
Able to read and work from blue prints
Fabricate to close tolerance .030
Be familiar with and able to use standard shop tools (saws, grinders, drill press, ect)
Be able to run a manual milling machine is a plus!
Immediate opening.
Compensation: Pending Experience
email contact: job-hjzxd-1527663094@craigslist.org
Fitter / Welder (Woodland, WA)
We are seeking a Fitter Welder for our client company in Woodland, WA
Company in Woodland has an immediate need for a Fitter/ Welder. Position is an Evaluation to Hire position. Individual will be welding 20% Tig and 80% Mig on stainless steel and A36 carbon steel products. Qualified Candidate MUST have solid tig welding experience. Must be able to pass a weld test.
The company designs, manufactures and sells knife gate valves. The company can design and manufacture virtually any configuration of fabricated knife gate valve or slide gate valve. Requirements:
Must have at least 5 years experience welding which includes Tig and Mig, Journeyman Level.
Plans and produces metal forms or objects, or reconstructs damaged articles of various metals and alloys.
Utilizes hand tools, fixtures, jigs, and clamps for small welding jobs.
Cuts metal using a torch and following diagrams or sketches.
Accomplishes welding that fuses different metals and withstands great strength demands while avoiding distortion.
Regulates equipment as necessary for the work performed.
Will be working in a fabrication shop. Must be flexible to work swing shift if they decide to run this shift, company makes large valves for pulp mills.
Must have own transportation
Must be flexible to work day shift or swing shift
Must be able to pass a pre-employment drug screen & criminal background check.
To Apply
Please submit a resume to jobs.longviewwa@expresspros.com or fill out an application at www.expresspros.com for first consideration than contact our office at 360-414-1200 between the hours of 7:30am-5:00pm Monday-Friday to discuss your qualifications and schedule a possible interview.
Compensation: $16.00 - $18.00 an hour
Be safe
John B.
Return to welding job bulletin board.
