Wire Speed Setting
by Sean
(Ga)
How do you set the right wire speed for the metal your welding? By thickness of metal or?
Sean,
its a function of metal thickness and position.
http://www.millerwelds.com/resources/calculators/mig_solid_amperage_calculator.php
if you go to the web page listed above, you will get a good starting point.
for me, the wire speed listed is always a little higher than you need.
for vertical uphill welds, just use a setting for one or 2 less thickness
for example, if you are welding 3/8 thick metal but welding vertical uphill, you might use a setting for 1/4"
the miller calculator will get you in the ball park
