which TIG to buy
by Dan
(Colchester, VT)
Thanks for the great site!
I am new to welding but have some projects that I'd like to do. I am restoring an old boat and need to make a swim platform. I'd like to make the frame out of stainless tubing. I would also like to be able to do a variety of other small jobs.
From what I've read on your site it sounds like a TIG welder is the way to go. It will have to be able to be plugged in to household power as I have no access to 240.
What machine do you recommend? (best 115/120V TIG machine for the money)
Any thoughts on the Lincoln Electric Invertec V155-S TIG Ready-Pak Welder? If I bought this one what else would I need to buy to be ready to weld?
Thanks for your help!
Thats probably a good unit. I know a contractor who uses one along side a miller maxstar 150 to weld stainless tubing all day. he uses both equally.
looks like it comes well stocked so you will need a cylinder of argon and some 308 ss welding rods.
I recommend 1/16"
then you need practice.
you dont have amperage control with that unit and you might need it for welding thin wall stainless tubing.
you might consider something like a miller diversion 180 that comes with basically the same stuff but can weld aluminum also and has a foot pedal amperage control.
