by scott
(new holstein,WI USA)
Hi, I work at a metal fab. shop and do alot of tigging aluminum. After it is sheared down to size and punched on a press at times they are very oily, and as you know that is Bad. They give us rags and brake cleaner to clean them before welding. I heard that some chemicals in brake cleaners can cause a lung disease. Is this right? What would you use to clean the aluminum??? thanks much
first, read this article on brake cleaner...
http://www.brewracingframes.com/id75.htm
just copy and paste the link in your browser address bar.
alcohol or acetone are much safer.
