What is the advantage of spray transfer compared to globular transfer with Mig?
by Paul Kingsbury
(Bend, OR)
Today I finally played with spray transfer “other than welding Aluminum with my spool gun”. It was kind of fun and interesting; I was using 75/25 mix and turned up the volume of gas to get good welds. I see a lower percentage of CO2 is recommended. I’m using 0.030 solid core wire in an old SP-200 Lincoln, I was almost at the top end of power and wire feed speed. It made good welds but the 1/8” metal I was welding on got REALLY hot.
Could you give me the pros and cons of spray transfer and why I would want to use it more?
Thanks, Paul Kingsbury
you really need a bigger power source to get the most out of spray
