Welding Video Review - Welding Aluminum with a Spool Gun from MillerWelds.com
Welding video of Aluminum mig welding with a spool gun
Aluminum wire is much softer than steel and is hard to feed very far thru a liner. That is the reason for spool guns. With a spool gun, the wire only has toe fed for a few inches. Whereas with a conventional mig setup, the liner is usually about 8-10 feet long. Trying to push soft aluminum wire thru a cable that long is challenging and mostly just not doable. The spool gun is the way to go. 1 pound spools of aluminum wire are loaded into a small gun that resembles a Tommy gun gun from old gangster movies. The spool gun is slightly less maneuverable than a conventional mig gun but the trade off is worth it in being able to consistently feed aluminum wire without bird nesting every few minutes.
100 % argon gas is usually the gas of choice but mixtures like 50/50 argon/helium can be helpful for welding thick sections. Make sure the polarity is connected properly. mig welding aluminum requires reverse polarity. Another way of saying reverse polarity is Direct current electrode positive or DCEP. The same polarity is used for welding steel with bare wire but since mig machines can be used for self shielded flux core wire also and some of those wires require using DCEN or Straight polarity, It is a good idea to check the polarity setup just to be sure.
The 1 pound spools shown in this welding video are available in either 4043 or 5356 alloy and other alloys too, but these 2 are the most commonly used. 5356 is a bit stiffer and is easier to feed. But the 4043 wets out better. 5356 is also slightly stronger. There are lots of considerations when choosing and there is a filler metal chart you can download at this link.....
the suggestion for setting wire tension is excellent. Trying to weld with not enough wire tension will cause burn backs and lots of cursing. Set the tension tight enough but not too tight. Too tight and the drive rollers will mash the wire and cause other problems.
Some important tips for mig welding aluminum:
1. Push dont pull. Pushing works much better whenever you can... But we both know that sometimes you just gotta do what you gotta do. Pulling the weld will cause it to be sooty but its not the end of the world. A stainless brush will remove the soot.
2. when setting the wire feed speed, start out high and then adjust lower. You will save lots of tips this way, trust me on this.
3. dont try to get the bacon frying sound like with steel, if you are getting this sound, your wire feed is a little to high. you are looking for a high pitched humm.
4. always snip the wire in between welding. this will save many tips
5. keep the stickout to around 3/4" and you will save many tips
6. keep a new pack of tips in your toolbox cause... damn! - mig welding aluminum , even on a good day , goes thru some tips.
It is possible to mig weld aluminum without a spool gun. I used to work in a shop that did this. A short mig cable, a teflon liner, and a softer tension spring allowed us to weld pretty well. The trick was to angle the mig gun to that about an inch of wire fed out before it contacted the weld area. Then you could change to a normal welding angle. If we didnt do this, we got a lot of burnbacks because the mig machine did not have any run out or wire feed delay features.
leave welding video spool gun page and read more on mig welding
more welding videos
welding videos - Shortage of welders
welding videos - welding contest champion
welding videos - virtual reality welding training
welding videos - welding training and welding schools
welding videos - tig welding clamps for headers
welding videos - aluminum brazing rods
welding videos - gas tungsten arc welding clips
welding videos - jesse james choppers and welding
welding videos - how not to weld, seriously
welding videos - mig welding
welding videos - tig welding 4130 chromoly
welding videos - tig welding aluminum
welding videos - tig welding aluminum bike frame
welding videos - welder shortage jay leno
welding videos - welding videos reviewed
