Welding in cold temperatures
Can anyone tell me if there is a certain temperature you should not wire weld steel? I am meaning the weather outside, freezing temperatures. Using .072 Hobart wire coreshield 8.
AWS codes usually require a preheat of the steel to around 65 or 70 degrees if the base metal is 32 or below.
if you follow that, i am not sure if there are other limits for welding in cold weather.
it will definitely affect the cooling rate of the weld and could definitely be a factor.
Comments for Welding in cold temperatures
Jan 03, 2014
welding in freezing weather NEW
by: Meloday
It is 8 degrees F here in NW Indiana. Can my utility company make a weld outside to connect my home to their gas line?
