holiday-deals-banner
welding cast alloy (cylinder head)
by gan boon san
(johore, malaysia)
hi,
i use TIG to weld the cylinder head, but i got a problem.when i start to weld the casting there are many bubble come out from the casting and the bubble will come out after i mill the cylinder head.got any solution to solve the problem? thank!
best regards.
Thats very common with any oil soaked or carbon impregnated casting.
often, it requires welding a little bit, then burring the weld back out with a carbide burr, then welding again, etc...until the metal cleans up.
its good to do a skim cut with a carbide burr every pass also so you dont get finished and have a bunch of holes as a surprise.
4047 filler can help too
