holiday-deals-banner
Welding Aluminum with TIG welder
If you need to know about welding aluminum with TIG welder, then this page is for you...
here is a checklist of the most important things to know
you need an AC/DC TIG welder and it needs to be set to AC
pure argon is the best gas for 99% of TIG welding aluminum
you need aluminum filler wire and 4043 is the most versatile type and 3/32" is a very useful diameter
2% lanthanated tungsten is a good all around choice for tig welding aluminum because it also works great on steels.  start with 3/32"
before trying to weld anything that matters, start by welding practice  beads on scrap aluminum until you can weld a uniform bead consistently.
If you get frustrated, take a free 7 day test drive at welderskills.com and take the Intro to TIG course.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
