by Petes
(UAE, dubai)
I am welding aluminum pipe with wall thickness 3mm using TIg process but i do not get a good finish or a satisfactory weld in the root side. do i need to purge on the root.do i need to have a root gap for 3mm. what other preparation should i take.
purge always helps.
but is not always a requirement .
one trick is to seal the joint with minimal heat and filler wire and to do a second pass where more amps are used to push penetration thru.
