vertical down MCAW
by Russ
(Ontario, canada)
i'm trying to qualify a Vertical Down procedure with metalcore 0.45 wire. i need to provide macroetching samples for 1/4" fillet on 3\4" back plate and 1\4" up plate , and i'm struggling to find the correct parameters. Any Help would help. Thanks
russ,
lincoln has some good spec sheets that offer parameters that usually are a good starting point.
http://www.lincolnelectric.com/assets/en_US/Products/Consumable_Metal-CoredWires-Gas-Shielded-Metalshield-MetalshieldMC-6/c3112.pdf
Comments for vertical down MCAW
Nov 09, 2013
Wire speed NEW
by: Anonymous
I usually burn around 23.8 and 24.8 volts. My wire speed verys between 350 to 400, when I burn at 24.8 volts i turn down my wire speed to about 300 to 350 and it gives me a nice down hand weld using mcaw.
