Using the proper angle when welding overhead while the lap joint is curved
by Shamus
(Middletown, De)
Hello, I am working on a job where I am welding a 1/4 inch thick carbon steel lap joint overhead
but the joint is curved up and about 20 feet long. It has to be 100 % seal welded. The beginning
of the curve is 4 feet off the ground and the end is 12 feet of the ground. So as you can tell I am
exposed to some weird gun angles. I am welding with a Miller Regency 250 using the high volt
range of 20V to 30V and the dial set to the number 3. I am also using the spoolamatic 30A with
the gun speed set to 4 which is about 4 feet per minute and a 2 lbs. spool. The shielding gas is
75% argon and 25% CO(2).
First question,
should I weld uphill or downhill?
I have trying both. When I weld uphill with the gun pointing straight at the middle of the joint with
a 45 degree angle up and down and 90 degree angle left to right the weld piles up. The same
when I weld downhill. The only time I can get a flat looking weld is when I weld downhill and
hold the gun straight at the middle of the joint on a 45 degree angle but left to right the gun is
almost at a 30 degree angle pushing the weld. Is the 30 degree angle to much? I can't seem to
found the combination of angles to get a flat looking weld or one that does not piled up. Any
suggestions? I forgot to mention that the power supply being used is a generator.
That sounds like a lot of wire speed if you are using .035" or .045"
I would try trimming the wire speed back a little.
a short stickout too of less than 1/2" from contact tip to arc.
you should be able to pull downhill on that angle of travel if things are set right.
