tips for passing weld certification test for first time
by Ernest Dickens
(Mobile AL. till next job)
it doesnt matter what kind of test it is the simple fact is that if it is your first test you will b nervous and nervousness doesnt help to produce a clean smooth weld relax because they need welders and take your time i have taken more welding tests in the ten years i have been welding than a few if u can weld u can pass any test if u havent ever done that particular type of welding then u need to practice before you take a test but if u have done it before then relax and take your time and everything will b just fine
