TIG Welding Thinwall Square tubing
Using the laywire technique along with 3/32' filler on thinwall square tubing helps with melting thru too much and pulling those oxides into the bead.
Clean metal, sharp tungsten, and good gas shielding are 3 keys
Try out a Jazzy 10 combo kit
METAL TYPE = CARBON STEEL SQUARE TUBING
THICKNESS = .063” WALL THICKNESS TUBE
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT JOINT
POSITION = FLAT
AMPERAGE = MACHINE SET TO  70  AMPS CONTROLLED WITH PEDAL  60-65 AMPS SWEET SPOT
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   PRE FLOW = .5 SECPOST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC ..
practice restarts until they blend in
Technique for Stopping and Restarting the bead
Being able to restart a TIG bead in a way that hides the restart is a great skill to work on.
One simple technique is to think of the crater where you stopped as a target with a bullseye.
Simple center up on the bullseye and increase amperage to match the crater and then proceed with the bead.
Try out a Jazzy 10 ceramic today...visit Weldmonger.com
jazzy10-2g-aerospace-welding
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = LAP JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = MACHINE SET TO 100-125 AMPS CONTROLLED WITH PEDAL  115 AMPS SWEET SPOT
FILLER WIRE = 1/16” ER706
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC ..practice restarts until they blend in
Did you know?...
***Its Easy to sign up
No Ads, No BS style
